주요 콘텐츠로 건너뛰기
Will not boot
At power up I get the apple chime then goes to the grey apple screen and the little circle just spins forever
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 1개
I finally replaced the hard drive, Price was right ,Larger drive install was very easy and the laptop is back and running fine
댓글 달기
답변 4개
선택된 해법
At startup, hold +S simultaneously, then when the code stops, type fsck -fy, this will run a hard drive repair. Hopefully it will repair your hard drive and you can type logout to boot up as normal.
If it does not work, you will need to try re-imaging your hard drive.
If that doesn't work, replace the hard drive.
이 답변이 도움이 되었나요?
점수 2
댓글 2개:
Volume Check Failed
I see, i suggest you re-image your hard drive
댓글 달기
I repeatedly had this issue after installing OSX 10.5 and then upgrading it to 10.5.8, eventually I realised that I had only 256MB of ram in the machine, so I swapped it for 1GB, and it booted up straight away. Also worth bearing in mind is that if one of the RAM slots has disappeared, as they do, this may leave you with only 256MB of RAM where you thought you had more! Another way to check what is happening is to boot while holding down Apple key and the letter 'V', this will boot the computer in verbose mode, which will allow you to see how far the machine has got, and if it has stalled.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
I replaced the Hard Drive very easy to install. Laptop running great
이 답변이 도움이 되었나요?
점수 0
댓글 달기
at power, i only hear the sound of fan.
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
Manny, this a year and a half old answered question. If you need some help please start a new question and give us a little more information. The more effort you put into your question, usually the better answer you get. Thanks
댓글 달기
답변을 추가하세요
Stephen Schenkel 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 3
지난 7일: 5
지난 30일: 20
전체 시간: 3,588
