Will not boot
At power up I get the apple chime then goes to the grey apple screen and the little circle just spins forever
좋은 질문 입니까?
좋은 질문 입니까?
At startup, hold +S simultaneously, then when the code stops, type fsck -fy, this will run a hard drive repair. Hopefully it will repair your hard drive and you can type logout to boot up as normal.
If it does not work, you will need to try re-imaging your hard drive.
If that doesn't work, replace the hard drive.
해당 답변은 도움이 되었습니까?
Volume Check Failed
I see, i suggest you re-image your hard drive
I repeatedly had this issue after installing OSX 10.5 and then upgrading it to 10.5.8, eventually I realised that I had only 256MB of ram in the machine, so I swapped it for 1GB, and it booted up straight away. Also worth bearing in mind is that if one of the RAM slots has disappeared, as they do, this may leave you with only 256MB of RAM where you thought you had more! Another way to check what is happening is to boot while holding down Apple key and the letter 'V', this will boot the computer in verbose mode, which will allow you to see how far the machine has got, and if it has stalled.
해당 답변은 도움이 되었습니까?
at power, i only hear the sound of fan.
해당 답변은 도움이 되었습니까?
Manny, this a year and a half old answered question. If you need some help please start a new question and give us a little more information. The more effort you put into your question, usually the better answer you get. Thanks
24 시간 전: 0
7일 전: 1
30일 전: 2
전체 시간: 3,364
댓글 1개
I finally replaced the hard drive, Price was right ,Larger drive install was very easy and the laptop is back and running fine
Stephen Schenkel 의
