주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2.3GHz, 2.6GHz 또는 2.7GHz 쿼드 코어 Intel Core i7 프로세서(최대 3.7GHz Turbo Boost), 6MB 공유 L3 캐시.
Slow performance after battery replacement
I recently replaced the battery on my 15" Mid 2012 RMBP. I'd installed a clean version of High Sierra before installing the battery. Since replacing the battery, the performance fo the Mac feels a but sluggish, glitchy almost.
Here's what I did:
Tried resetting the SMC - which didn't seem to even work properly. The light on the power cord didn't blink to indicate anything had happened.
Startup progress bar also seems to stall for a noticeable 5-10 seconds now, about 3/4 of the way through. Not a killer, but a noticeable difference.
Any thoughts are appreciated.
Thanks!
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 4
댓글 달기
답변 4개
선택된 해법
Sometimes faulty batteries can cause Cpu throttling. I'd suggest trying unplugging the battery connector and check how the laptop behaves with Dc in only. If everything gets back to normal, it might be just a faulty battery problem.
이 답변이 도움이 되었나요?
점수 2
댓글 1개:
Oh man ...
If this turned out to be a faulty battery from iFixit I might flip my top. I can’t imagine having to do that replacement again.
댓글 달기
Got the new battery, bought from eBay.
There's no more throttling, everything running Fine.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
I had to remove the battery and I'm also facing the CPU Throttling.
My CPU should run at 2.3ghz, but Intel Power Gadget and Windows Task Manager shows it running at 1.1ghz.
My new battery should arrive next month, I'll post the results when I get it.
If you have any progress please share with us.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Any news?
Did it throttle under your new battery
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Zach MacDonald 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 6
지난 30일: 18
전체 시간: 5,391
