주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
식기 세척기 수리와 분해 안내서 및 지원.
Fixing an LG Dishwasher LE error code
My dishwasher stopped working when it started giving me an OE error code. Turned out to be a bad drain pump, which Ive replaced. After replacing the drain pump, I now get an LE error code. I wasn't getting this before. I understand the LE error code is associated with the water pump not working, but I find it hard to believe that the pump just failed at the same time as the drain pump. Is there something I could've messed up while replacing the drain pump that would cause this? When I start a Rinse cycle, I hear the dishwasher go through a drain cycle first, then the fill valve opens and I hear it fill with water. When it's time for the water pump to kick on, I just hear kind of a "Egh" noise a couple times, before it throws the code, almost as if the impeller is stuck or something.
I noticed a couple screws were stripped that screw the top piece (filter part) into the whole sump assembly. Besides that, couldnt find anything else.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 1개
I just replaced the sub pump and it was working fine for a few days then it started throwing the LE code
댓글 달기
답변 3개
가장 유용한 답변
An LG Dishwasher that displays the OE error indicates a DRAIN ISSUE. This means when the LG dishwasher gets to the time for it to drain out water, it is not draining correctly or cannot drain. This is caused by a CLOGGED DRAIN HOSE or a CLOGGED OR FAULTY DRAIN PUMP.
UPDATE
The LE error code on the LG dishwasher display is an indication of a MOTOR ERROR. The 5 issues that may cause this fault code is a wiring problem (most common reason for LE error), the impeller of washing pump is locked, the rotor of washing motor is locked, the blade is locked, or the PCB main control board is faulty.
이 답변이 도움이 되었나요?
점수 4
댓글 2개:
OE was the original code that I fixed, but in doing so, somehow caused the LE code that Im getting now.
do you have any information for fixing the problems you mention above? we tried turning off the circuit breaker for 10 seconds and turning it back on, but that didn't help
댓글 달기
I guess I got lucky and used my Hi Tech Skills when I got the LE message. Just now, this minute. I unplugged the machine, waited 30 seconds then plugged it back in. Worked like a charm 😂
All those years of calling internet providers to reset my modem has paid off
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
had same problem: opened and closed the door and that was it! continued the cycle as usual
댓글 달기
Sounds like the pump may have a small piece of glass stuck in the vanes, must be stopped for a reason. May have to pull it out and hook up to power supply or see if pump can be moved or replace with new one. These parts are light duty and can fail or get damaged rather easily sometimes.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Brandon Thompson 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 9
지난 7일: 78
지난 30일: 423
전체 시간: 61,874
