My charger doesn't charge.
After going down from lack of battery, my tablet won't charge. The charger Light doesn't turn on, and I need some solution that doesn't involve buying a new one or throwing everything against the wall...
좋은 질문입니까?
좋은 질문입니까?
@gc05 you could check your charger with a multimeter first to make sure that it is working. If it is then you are possibly having issues with either the charging port Microsoft Surface 충전 포트 교체 or the battery. If your battery is depleted or discharged below the charging threshold it will no longer accept a charge. Replace the battery and see if that works. Microsoft Surface 배터리 팩 교체
안내서
난이도:
조정
5 - 10 minutes
안내서
난이도:
조정
15 - 30 minutes
이 답변이 도움이 되었나요?
지난 24시간: 2
지난 7일: 4
지난 30일: 13
전체 시간: 25,466
댓글 1개
Just tested with a multimeter, and apparently the charger is working...
The problem must be in the battery.
Gil Cancela 의
