주요 콘텐츠로 건너뛰기
IBM ThinkPad T30, introduced in May 2002.
6 질문 전체 보기
IBM T30 won't start up
This laptop hasn't been used in a few years now but before that it was fully working. I tried to turn it on and some lights do come up but none of the fans seem to be running.
I unplugged the battery and plugged it with the charger, unplugged the cmos battery, did the 10 second reset when the battery is out but still nothing.
Does anyone know what might be the problem?
Thanks in advance
Pics: http://prntscr.com/j5hkbl
http://prntscr.com/j5hke3
http://prntscr.com/j5hkgz
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 3개:
Do you get a BIOS splash screen?
Hi @notanexpert
Try reseating your keyboard LVDS connector and ON the laptop again.
I do not get a BIOS splash screen. Sometimes the screen turns on with no display (rarely) but the laptop's components don't seem to be working well.
I tried reseating it but still nothing
댓글 달기
답변 1개
There is a fairly common RAM issue with the T30 models that causes the RAM sockets to come unsoldered from the motherboard over time, which would basically disconnect the modules from the computer over time.
The easiest way to get around this is to just replace the motherboard entirely, but if you are more skilled with soldering, then it is an option to just resolder the pins from the RAM slot to the motherboard. There is some helpful information on the ThinkPad forum here that you may find a good read within.
Good luck!
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
notanexpert 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 5
지난 30일: 10
전체 시간: 1,288
