Is the GPS and WiFi antenna the same
some one told me their GPS does not work, now call me silly but isnt this the same as wifi?, and if so when i tested the wifi it worked perfectly
좋은 질문입니까?
좋은 질문입니까?
Well no, the WiFi and GPS antenna are different.
YES the location tracking on an iPhone usually works using WiFi hotspots (accessing them to track your location).
But no it's a different component, if the GPS isn't working it's most likely something wrong with the location services, or the IC of the logicboard
(Murata 339S0228 Wi-Fi Module is on one side and Qualcomm QFE1100 Envelope Tracking IC, RF Micro Devices RF5159 Antenna Switch Module and Skyworks 77356-8 Mid Band PAD on other side of logicboard, see iPhone 6 분해도 for more info, btw in case you need to replace, see iPhone 6)
이 답변이 도움이 되었나요?
Hi,
My RF5159 Antenna Switch Module Ic Chip, has fell off from my motherboard, and I can't find not tutorial whatsoever on how to reinstall it, do someone know about any link on how to do this? Thanks.
from my knowledge, it is the BT/WiFi that run off the same antenna.
GPS uses Wifi Signals to help Tune the signal into something more percise, but doesnt base its function out of the same chipset. which means if it is just strength issues, the antenna would be at fault, but if there is absolutely zero function, you are likely looking at a board level failure.
try replacing this compoenent, and if not, then board work may be needed.
이 답변이 도움이 되었나요?
What can be confusing is your phone uses two additional methods of triangulation: Celluar and WiF besides GPS/GLONASS satellites. Here's a bit more: GPS Navigation
The antennas are within the case its self (top & bottom isolated surfaces). The flex cable here is a signal guidefrom the logic to the cases connection point.
More likely, the GPS logic within the logic board has been damaged.
지난 24시간: 0
지난 7일: 6
지난 30일: 7
전체 시간: 5,769
