주요 콘텐츠로 건너뛰기
An all-new model (codename XD) was launched in 2000. The estate was dropped in favor of a five-door hatchback. Starting in 2001, all American models came with standard front and front-side airbags, air conditioning, power locks, power windows and power steering.
8 질문 전체 보기
Why is my car dying while driving?
I have a 2003 elantra and have recently had issues with it. Over the course of the past few months, it has stuttered and slowed to a stop while I was driving and then not started for a few minutes following the incident Without fail, if I wait 5-10 minutes and try to start my car again, it will turn on. Today, it escalated. After driving over 250 miles, my steering wheel locked and my car started to slow then die. A mechanic pulled over to help me and was not familiar with my model of car, but said it seemed to be an issue where the engine was not registering that fuel was in the car. (Jump start and starter fluid did not work). I'm supposed to drive another 300 miles tomorrow and I don't know if I should take the car in or hope for the best regarding the drive. Anyone know what it could be and how much it would cost (and how long it would take) to fix such a problem?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 2개
가장 유용한 답변
b fleck could be many issues but since you said that "starter fluid" did not work it could be a bad camshaft sensor, a bad crankshaft position sensor or anything electrical. Best would be to have the OBD scanned and see if it throws any codes.
해당 답변은 도움이 되었습니까?
점수 1
댓글 2개:
Hi @oldturkey03 ,
Also of concern is why did the steering wheel "lock", "....my steering wheel locked....".
Possible faulty ignition key lock perhaps which may also affect the electrics
b fleck @jayeff is of course absolutely right. Check your ignition lock first! It could most certainly be the culprit.
댓글 달기
Change the catzilla box to the so-called pollution tray
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
b fleck 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 26
전체 시간: 804
