Mouse Pad not working
When i switch on laptop approx 5 to 10 minute not working properly but after that not worked ...
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 2개:
Hi,
What OS is installed in the laptop?
Just verifying that when you turned on the laptop, the trackpad did work but not correctly and then failed to work, is this correct?
Does it do this every time you restart the laptop, i.e. works and then doesn't work, or has it now failed completely?
Try using a USB mouse until the problem is sorted
의 공유
Dell Laptop Mouse pad not properly work
의 공유
댓글 달기
