주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Polar M400 Watch는 심박수, 속도, 거리 및 경로를 포함한 사용자의 훈련 데이터를 모니터링합니다.
A button has been jammed
The button that takes me down in the menu is stuck in depressed mode, making sure the screen always shines at maximum power. This means that my battery life is only a few hours. how can you solve it?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 9개
The back button (bottom left) is stuck for me. I'm having very little help from the support centre in UK
의 공유
I have this exact same problem
의 공유
I have the same problem, but with two buttons (LIGHT button and DOWN button). I managed to "un-stuck" them both, but now I cannot use them.
의 공유
The DOWN button is stuck. Would you please let me know how to un-stuck it?
의 공유
I have the same problem. The down button is stuck
의 공유
댓글 4개 더보기
댓글 달기
답변 5개
가장 유용한 답변
I had the same problem with my M400 watch. The top right button was jammed.
My solution was this: open the watch and remove the pcb and everything from the inside. Take some tweezers and dip them in a fine mechanics oil (Ballistol for example, or any thin oil that doesn't harden. But please no WD40!). Then push the button and apply the oil on the pin that pushes the contact on the pcb. Try to press the button some times until it goes smoothly. Than reassamble the watch. Be careful: collect any drips of oil before the assembly.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
If you guys needed an answer still,
I used a bit of bluetack pressed down hard on the button and it managed to pull the button out.
Hope this helps.
Not a long term fix but works short
이 답변이 도움이 되었나요?
점수 0
댓글 달기
It is VERY easy to open this watch. The battery and button contacts are attached to the back plate. Only four little screws to remove once the strap has been removed. I suggest opening, careful cleaning, and checking of contacts. Then re-assemble. See here for how to open:
Polar M400 시계 배터리 교체
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Hi Patrick, if you feel confident enough, this is what i did to free up the buttons. Removed the outer case, you’ll need star screwdrivers, then undid the circuit board screws ( Philips-head) and removed the unit completely for access, I didn’t bother to disconnect the battery. Once out I have a Jewellers eye glass as the parts are exceedingly small. Depressed the sticking button and removed the small securing clip holding the button in place. Make sure you’re doing all this on a white linen cloth as the parts are very easy to lose. Once the clips removed the button comes out. There you’ll find a metal washer, a rubber gromit and a small spring. I just gave everything a clean and the spring a slight stretch before putting everything back in reverse.
the tools I used were:
Star screwdriver
Philips-head screwdriver
thin nosed tweezers
A cup to hold the screws
Jewellers eye piece
let me know if this helps.
Michael
이 답변이 도움이 되었나요?
점수 0
댓글 달기
I wasn’t keen on opening it up. I’ve had the bottom left button jam twice and each time I’ve used beard trimmer oil and it’s sorted it out after a few hours.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Patrik Berglund 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 14
지난 30일: 64
전체 시간: 9,878
