주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
모델 A1001 또는 A1025 / 667, 800, 867, 또는 1.0 GHz G4 프로세서
repeated crashes after memory upgrade
I upgraded my G4 Titanium 867 DVI memory from 512MB to 1 GB. The computer recognises the memory. System profiler says its OK. After a few minutes of operation programs start crashing, then the computer crashes. I re-installed the memory twice but the problem persists. Reverting to the old memory chips removes the problem. I am running osx 10.5.8
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 -1
댓글 달기
답변 1개
선택된 해법
You solved the problem. Please tell us all about the new RAM.
이 답변이 도움이 되었나요?
점수 1
댓글 5개:
The new RAM is labelled SMT 512MB SO DIMM PC133 8300UC www.siliconmemnory.com. Each module has 8 chips on each side, six in a row and two at right angles behind.
의
Some RAM chips that are made for PCs will not work in MACs. I do not recognize the SMT and could not find RAM listed at www.siliconmemory.com. I would get RAM from a suppliers that specifically handles MAC such as:
http://www.ramdirect.com/51pbg4tisopc.ht...
의
I bought the RAM from a MAC specialist. From my research on the internet it seems identical to that being offered by a number of RAM suppliers for this particular computer. I'm in Hobart, Australia, so my sources are limited. If I can't solve the problem I'll return it to the supplier and order on the internet. I'm wondering whether resetting pram or pmu might help. Haven't tried that yet.
의
I don't think it will help but try removing the battery and AC, hold the power button for 10 seconds and then retry it. Just tell your supplier what is happening.
의
Thanks, I'll try that. If no result I'll contact the supplier for advice tomorrow. I thought perhaps it might be a common problem with a simple answer, but it appears not.
의
댓글 달기
답변을 추가하세요
Rex 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 10
전체 시간: 836
