주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
모델 A1225 / Early 2009 / 2.66, 2.93, 또는 3.06 GHz Core 2 Duo 프로세서
OS-X El Capitan install from pkg
Hi, as per a suggestion to download El Capitan from a direct link being
http://osxapps.itunes.apple.com/apple-as...
I now have this file and am unable to use it to create a usb, I have later read a whole process may be involved to link the download to a local host ect.
I just clicked on the link to download, now I'm out of mobile data till the end of the month if there is no way for me to use this file.
Can anyone help please :-)
Update (04/23/2018)
When I click on the package it says:-
The operation couldn’t be completed. (com.apple.installer.pagecontroller error -1.)
Couldn't open "ftk3252456602304584541.pkg".
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 1개
This is not a real Apple download! I recommend you don't use this file! You need to get the real file from the Apps store from a Mac system that is working.
댓글 달기
답변 1개
가장 유용한 답변
You'll need to create an install USB Thumb drive following these instructions: How to make a bootable OS X 10.11 El Capitan installer drive
The installer won't work without being mounted from a different drive or partition that is Mac OS-X/macOS.
But before you go down this path how about telling us a bit more on why you think you need to install the OS.
이 답변이 도움이 되었나요?
점수 1
댓글 2개:
Thanks for the reply, I went the long way….. Then I found my Snow Leopard disc !
I was setting up a 2009 iMac, El Capitan was the best it could do. But the old OS-X did not have the app centre. I could only find .pkg download. In the end I got it to work as I had limited time, the next week I found some old Leopard disc that I could have used to make things a little easier.
All is running well, now it’s just the constant tutoring of a 76yr senior who has never used a Mac let alone a pc.
Cheers.
Happy it all worked out!
댓글 달기
답변을 추가하세요
Leigh 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 7
지난 30일: 33
전체 시간: 7,853
