Backlight out, can see with flashlight and changed inverter didnt fix.
I have a samsung 32" lcd tv model number LN32D450G1D. On day the backlight just stopped working everything else still works and can see the image on my screen with a flashlight. I bought a backlight inverter and switched it out with no fix. What else could be the problem? Also when I turn the tv on the power button blinks 5 times. I checked all the capacitors and none looked damaged or bulged also all the wiring looks good.
Thanks for the help
좋은 질문 입니까?
댓글 1개
I Just replaced the main board with no fix this past weekend. So far I've replaced the back light inverter and i'm not able to replaced the t-con board due to it being part of the actual lcd panel, which i don't think is the issue because doesn't have any t-con board symptoms, All I have left to replace would be the power supply is which I am guessing is the problem. I did a test where I unplugged the main board and then plugged the Television back in and the back light blinked for a second when i powered it on so I know it is being recognized. I'll replace the power supply next weekend if I could get the right price and give an update.
Mick 의
