주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2015년 9월 25일 출시. Model A1688/A1633. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 6, 64, 또는 128GB / 은색, 금색, 스페이스 그레이 및 로즈 골드로 제공하였습니다.
Screen Not Working After Replacement
Hello all,
I just replaced a screen on an iPhone 6s, and after I put the screen on, it won't light up showing me it's on. I can hear the little reminder noise, so I know that the phone is on. I have put the old screen back on, and the screen still won't turn on. I have tried disconnecting the battery and reconnecting it, but it still hasn't solved the problem.
Does anyone know what's up with this phone?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 3개
선택된 해법
If the screen got replaced while the battery was left plugged in the backlight circuit is probably blown which can only be fixed by microsoldering.
Some repair shops do board-level repairs / microsoldering which you may be able to find locally in your area.
What usually happens is when you disconnect or connect the screen while the battery is still plugged in you may see a puff of smoke coming from the screen connectors meaning the backlight filter blew up.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
Could be that you got a defective screen, it's about 1 in 10 screens that I replace are non-functional. Also there is the possibility that the backlight blew.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
99% your backlight filter is blown!
http://mendonipadrehab.com/entries/gener...
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Benjamin Gabriel 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 3
지난 30일: 18
전체 시간: 942
