주요 콘텐츠로 건너뛰기
6s와 유사한 하드웨어 사양의 4-inch iPhone은 2016년 3월에 출시되었습니다. 16/64GB 저장 옵션 및 은색, 스페이스 그레이, 금색 또는 로즈 골드로 제공됩니다. 모델 A1662 및 A1723.
1049 질문 전체 보기
Water damage, not booting up but flashlight is on
The iphone in question does the iPhone SE. It will not boot up after being dropped in the swimming pool and the flashlight will stay on when plugged . Have already tried cleaning logic board and other parts will not work. What should I do
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
How exactly have you cleaned the logic board? I usually advocate for fully removing the board and scrubbing down with IPA. However, the SE is literally entirely covered in shields so it's very difficult to do a proper cleaning with removing the shields.
A professional repair shop that does water damage repair may be able to recover your phone or the data because they have access to pro-level ultrasonic baths and specialized cleaners, the tools to remove the shields as well as the skills to troubleshoot your board. Many shops have a no fix/no fee policy so you don't have to spend money to find out if the phone is fixable or not.
해당 답변은 도움이 되었습니까?
점수 2
댓글 2개:
Do you have any recommendations on how to remove the shields?
The shields are soldered on the logic board so they need to be be desoldered.
댓글 달기
귀하의 답변을 추가하세요
Mason Thomas 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 128
