주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Kenmore 전자레인지 수리 및 분해 가이드.
Works great except loud buzzing
So so thought it was the diode replaced that.
It still heats food and water 1 cup in 60 seconds to boiling.
What's my next move ?
Capacitor ?
It's heating, so magnetron isn't the problem right?
Buzzing is constant soon as you start cook cycle starts within 3 seconds of pressing start.
Prior to this constant buzz it was only happening when magnetron was firing.
could tell because you'd see food or water boil when buzz was there .
For example during a 4 minute or longer cook cycle. A year ago it would not begin buzzing within seconds of pressing start. It would only buzz when magnetron was hearing.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 1개:
My microwave makes loud buzzing from start to finish, but it has always worked. To me, along with the abnormally loud buzzing, my microwave heats and cooks slow for its size. Everyone who comes over to visit me notices how loud my microwave is when i turn it on to heat something up, they mention how loud the buzzing soynd is .... and it scares them.
I know it's related to the magnetron's function because when defrosting food the loud buzzing comes on and turns off intermittently as food is slowly defrosted.
Recently, using my opened palm, I bumped the bottom side of my microwave a few times while it was operating to see if that would cause the buzzing noise to change and the next day the buzzing was noticeably quieter while running the microwave. Also seems to heat up and cook faster now.
의
댓글 달기
답변 1개
To keep from being a parts jockey, please understand the following:
A microwave that is heating normally does not have a problem with the magnetron, HV diode, HV capacitor, door switches, or transformer. If any of those are bad, you will not get heating.
If the HV diode is bad, you won't get heat and it is unlikely that the internal fuse will blow because they usually blow open not shorted, but it might happen.
The transformer, magnetron and capacitor may blow the fuse but it is unlikely the transformer will fail and the magnetron is the lesser suspect.
Door switches on the other hand are the most common failure, either because they fail, or the mechanism that activates them is worn or misadjusted.
Door switches, mechanisms and adjusting (most newer MW eliminated adjustments) are simple for any mechanically inclined person with a multimeter. Diodes are the easiest to replace and cheap on Amazon (2x for $10.00 and cheaper on Aliexpress).
They are also easy to troubleshoot, since they usually burn up. If the magnetron is bad it is time for a new MW.
I am betting 98% of the MWs in the dump are simple, cheap repairs - Diodes, or door switches. And that is truly a waste.
HOWEVER, IF YOU OPEN UP A MW YOU MUST KNOW HOW TO NEUTRALIZE THE HV STORED ON THE CAPACITOR.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Will Williams 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 12
전체 시간: 338
