주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Grand Prix는 2004년 GM W 플랫폼의 개정된 버전으로 업데이트되었으며, 2002년 2월 7일 시카고 국제 오토쇼에서 Grand Prix G-Force 컨셉트카로 처음 공개되었습니다.
Multiple System Warning lights on
The transaction control, service break system and service abs system warning came on all at once in my 04 pontiac grand prix 3.8 . I have all new breaks all the way around. And replaced the right rear wheel bearing abs hub per the scan results. The lights will go off for awhile then come back on. Battery and Alternator were checked and they are in perfect working order
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 1개
The Gran Prix was the biggest piece of garbage GM ever made........And the answers you get from these sites are all guess work
의 공유
댓글 달기
답변 3개
선택된 해법
@vulkus has given you a good start(which he should have put into an answer so we can vote for it ) . You mentioned service break system light was on . when you changed the breaks did you open the system to air if so you may need to bleed the system are the brakes spongy or do you need to pump them to get stopped . Or had brake fluid been added to the system then when you put new brake pads on did it overfill the system as less fluid is needed with new pads . Check fluid levels regardless . If you have open tone rings check them for mud and road grim . if there sealed rings then check the wheel bearings seals for leaks . if grease is coming out dirt can get in and plug the tone ring . Finally does the traction control cause the car to shudder in sharp turns or or send vibration through the steering on long slow curves? let us know . Hope this helps
이 답변이 도움이 되었나요?
점수 4
댓글 4개:
Everything has been done properly. Scan shows no errors since I replaced the rear abs hub assembly. But warning keeps coming back intermittently
의 공유
Oh and everything works great. Breaks respond perfectly. No control issues. At this point I'm just gonna replace the 3 remaining will bearing hubs/sensor's (they are one unit) and see what happens because everything else has been done. After all it can't hurt the cars 14 years old. Thanks for trying :)
의 공유
Before you go buying new hubs, try to replicate the problem on other wheel sensors. Swap the left rear wheel sensor with the right rear wheel sensor and see what happens. It could be a wiring issue. Also get brake cleaner and spray the bejesus out of the tone rings, while rotating the wheel. (on jack stands).
의 공유
Is the battery good in the key fob this can keep the car from starting and cause all kinds of electrical things to happen
의 공유
댓글 달기
You will need to check if there is a fault with your front and rear abs wheel sensors. Hook it up to a scanner, reset all the codes. Drive it and see what resets.
Check all your wheel sensors by removing and visually inspecting the units. Wipe any grime or grease off them then replace. Check all the ABS sensor cables make sure they aren't broken or damaged in any way. Replace any suspect ones.
Last of all check all your fuses.
이 답변이 도움이 되었나요?
점수 2
댓글 1개:
Thank you for your reply
I already did that and no error codes when I scan it since rear hub/abs replaced. But still getting warning. :)
의 공유
댓글 달기
I have the same problem with a 2004 Grand Prix. ABS, Brake and Traction warning lights on dash and in the warning display. I took the battery out for a day trying to reset it but it didn’t help. It started immediately after the previous owner had the transmission replaced so I suspect it was something that the shop did. I hope you can figure it out and let me know if you do. I was given the car so I don’t want to put a bunch into it. I may take it to the dealer and see if they can reset it.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Robyn 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 3
지난 7일: 11
지난 30일: 42
전체 시간: 8,425
