주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2012년에 출시된 Lenovo K 시리즈 데스크탑 모델인 K410은 3단계 속도 조절 전원 스위치와 3세대 Intel Core 프로세서를 탑재하고 있습니다. 뛰어난 그래픽 성능 덕분에 게임용으로 탁월한 선택입니다.
Why is my computer not loading?
Every time i turn on the PC it says “preparing automatic repair” then a little message pops up with a blue screen stating that my PC did not start correctly. It then gives me several options to fix the problem and I have tried them all and nothing is working
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
선택된 해법
What version of windows are you using and do you have a disk for it? Some things to try before going overboard on running repair programs . First unplug the computer so it has no power then hold the power button down for a 60 second count . This will allow for a clean boot . Next if this brings no joy boot into safe mode(would tell you how if I knew which version of windows you are using) with command prompts then run an sfc scan this will repair most files and if not it will prompt you to run the repair disk . If it will boot in safe mode run a virus scan as many viruses emulate a system failure . Something else you may want to try is removing one stick of ram and running only one if no joy try the other one . Bad ram caan cause a blue screen error. Hope this helps
이 답변이 도움이 되었나요?
점수 3
댓글 달기
답변을 추가하세요
Vcampbell 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 11
전체 시간: 573
