This is the best way I can think of.
1. Open the Settings app and go to “General”
2. Choose “Storage & iCloud Usage”
3. Go to “Manage Storage”
4. Locate the iOS software update that is nagging you and tap on it
5. Tap on “Delete Update” and confirm that you want to delete the update*
This deletes the available iOS update which stops the iOS update from popping up every day, however, the moment you’re on a sustained wi-fi connection for a while the iOS update will download itself again automatically and start sending pop-ups to install it again. If this happens, just redo the steps.
You won’t lose the ability to install the iOS update, you can download it again yourself by going to Settings > Software Update, or just join wi-fi and leave the device unattended and it will download automatically without prompting.
I hope this helps!
댓글 2개
That pop up isn't the iOS update pop up, it's the carrier settings update.
Leo Terray 의
Doesn’t work. It deletes it but it comes back in a few days. Eventually it stops for maybe a month. But then comes back again, despite my automatic updates being supposedly disabled. I’ve had the slider to off for almost a year, and I’ve deleted update pushes form apple about 40 or 50 times. This is an old “fix” and is only temporary. I’ve deleted the iOS 12 update 4 times in the last week, alone, despite doing this “fix” last winter.
sickofthisshit2018 의
