주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
이 노트북은 2010년 9월에 출시되었으며, 모델 번호 Inspiron N5030 또는 Inspiron 15로 식별됩니다. 전체가 검은색인 노트북으로, 윗면 덮개 중앙에 DELL 로고가 있고 마우스 패드에는 좌우 버튼이 분리되어 있으며 노트북 오른쪽에 디스크 드라이브가 있습니다.
The computer will just not boot
Hello,
The computer will just not boot.
Tried loads of trouble shooting with some stuff found on line.
Set to boot from external USB, but it does not seem to "pick it up" and just sits there.
Could be it that the version of the Windows for booting on the USB must be a "bootable"version?
Thanks if anyone has any ideas-
G-
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 1개:
If i remember correctly it must be bootable version. If it's not bootable it will be behaving like any installer (which you must be already booted). I recommende you get a bootable windows and check connections of your ports with motherboard (if it's soldered) if it's still not detected.
의 공유
댓글 달기
답변 1개
You'll need a USB that's correctly formatted, and has a bootable version of the desired operating system.
Most importantly, you'll need to ensure that your BIOs are set to boot from a USB drive.
(If you're running off a solid state drive, with Windows 10 in particular, it can be tricky to get to the BIOs menu -- fortunately, that shouldn't be an issue with the system you're using, unless an SSD was installed afterwards)
You can also diagnose certain issues and troubleshoot by using a bootable toolkit, in order to see if there's damage to the hard-drive or file system.
However, if you never see any text display on the screen during boot-up, then it's likely to have much more extensive issues than just the operating system, or hard-drive.
Best of luck.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Gail Soberman 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 1
지난 30일: 8
전체 시간: 819
