주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Garmin Nuvi 65LM GPS는 2014년에 출시되었습니다. 이 기기는 6인치 이중 방향 디스플레이, 무료 평생 업데이트가 포함된 사전 로드된 지도, 수백만 개의 검색 가능한 관심 지점(POI)을 특징으로 합니다.
GPS stopped working after map update
My GPS stopped following and showing the rout, and giving directions
after I did a map update, 5.60 version, with "Garmin Express" software on
my Mac PC. How to troubleshoot the problem?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 1개
Are you Facing Garmin GPs is not working after the update? These types of errors showing due to technical faults and hardware malfunctions. We have to share some causes and Troubleshooting Steps to resolve these issues.
Causes of Garmin GPS Not Working after the Update:
1. Garmin GPS is Not working
2. Garmin Nuvi stopped working
3. Garmin Map Crashing
4. Touch Screen is Not Working
5. Garmin GPs Won’t Turn On
Fix Garmin Express Not Working After Update:
1. Click on the start menu button and go running window and also types ‘services. msc’ in the search field.
2. Click the Enter button.
3. After that, you will show the Garmin Core update service option and right-click on it.
4. Go to the account setting in which select the network service. Make sure that any password is filled from the provided field.
5. click on the ok button, until you can see the apply button that will save you all the changes made setting.
6. After that, right-click on the Garmin core updates service and then click on the stop button.
For More Solutions just click Here: https://bit.ly/3AoKcOC
In case you can face any difficulty in applying these steps and find any free Garmin Map updates you can directly contact a Garmin expert through Chats Support.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Gene Ras 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 3
지난 30일: 22
전체 시간: 715
