주요 콘텐츠로 건너뛰기
MacBook Pro 13" Retina Display, 모델 A1502의 2015년 3월 업데이트는 5세대 Intel Core i5 및 i7 프로세서를 포함하며 Force Touch 트랙 패드를 소개합니다.
1185 질문 전체 보기
White screen with some black border and lines?!
Hi,
I replaced screen and everything worked very well until I saw that Display is not tied great and it was loose. You can move whole display back and forward for like 0.5cm.. So I open my laptom and tied some screws. Everything was great until I turn on computer and display wont show. I attached everything as I should and it just stoped working.
I plug external monitor and everything is working fine.
So there is 100% something wrong with display. Hope that is LDSV cable.. :/
Ill attached a photo of screen. Its white with some vigneting black border and some black lines.
Here is photo:
https://ibb.co/i2a3Y8
Is this LDSV cable error or did I do something to my new screen? :S
Thanks for all replies!
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
LIFE_OF ROK double check your work. This "until I saw that Display is not tied great and it was loose. You can move whole display back and forward for like 0.5cm.. So I open my laptom and tied some screws" is what makes me wonder if there is something that went wrong with the installation. The best would be that you redo everything based on this guide MacBook Pro 13" Retina Display Early 2015 Display Assembly Replacement It is possible that it is your cable/connector but until you check, it is difficult to confirm. right now all you are getting is the backlight but no signal.
해당 답변은 도움이 되었습니까?
점수 0
댓글 2개:
Thanks for quick answer. I do like 10 times with this guide and its still the same.
:S Do you think that this could be display error or cable?
Check the cable for any damage on the connector. If it does look okay then it could be the display.
댓글 달기
귀하의 답변을 추가하세요
LIFE_OF ROK 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 5
전체 시간: 698
