주요 콘텐츠로 건너뛰기
Dymo LabelManager 160 is fast, compact and lightweight, making it easy to label just about anything, anywhere. Type quickly on the computer-style QWERTY keyboard, edit with one-touch fast-formatting keys and print for perfect, professional labels every time.
Dymo Label Maker 160 How to reset double lines?
Our label maker is stuck on text setting with two lines. How do we reset it?
Have read the instructions where it isn´t told and tried "everything".
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
선택된 해법
Hi @ullis ,
By " tried everything" does that include a power refresh?
If not try the following:
1. Remove the batteries from the device.
2. Press and hold the power button on the label maker for about 10 seconds to remove any residual power left in the device.
3. Reinsert the batteries and turn on the device to check if this has resolved the problem.
이 답변이 도움이 되었나요?
점수 7
댓글 6개:
Thanks! Have tried to remove the batteries but not hold the power button. :)
Thanks! This solution worked perfectly!
Thanks that worked perfectly and was a great help after weeks of that function not working - Merry Christmas
That did the trick! Thank you .
Very helpful. Problem solved!
댓글 1개 더보기
댓글 달기
답변을 추가하세요
UlricaB 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 21
지난 30일: 69
전체 시간: 15,558
