주요 콘텐츠로 건너뛰기
2015년 9월 25일 출시. Model A1688/A1633. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 6, 64, 또는 128GB / 은색, 금색, 스페이스 그레이 및 로즈 골드로 제공하였습니다.
2690 질문 전체 보기
Proximity and ambient light sensor
Hi everyone, I have a problem with the proximity sensor and the ambient light sensor of my white iphone 6s. I replaced the front panel with a non-OEM part. at first the proximity sensor did not work. with an indelible marker I obscured the sensor housing and worked. if I make a call and then put the phone to my ear, the display goes off. if I receive a call and the phone is on the table, when I put it to the ear the display goes off. if instead I receive a call and take the phone out of my pocket and put it to my ear, the display will not turn off. I did a test: if I receive a call and I cover the proximity sensor before answering, the display will not turn off. if, however, I cover the ambient light sensor before answering, the display on call will turn off. if I receive a call and the phone is in my pocket, I answer, press the home button and then return to the call, the display if I put the phone to my ear, goes off. what could be the defect? thank you all
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
선택된 답변
Did the replacement screen come with the Front Camera Sensor flex pre-installed? If so, those usually contain a lower quality aftermarket flex and can be the root of your issue. In that case, I would recommend you transfer over the original flex from your damaged screen, following this guide.
If you did migrate your original flex, then tale a closer look at it to see if the flex was damaged, such as a tear or broken connector pin).
Update (05/24/2018)
Hi @refectio
the screen arrived without flex. the sensors are original apple. in these two days I disassembled and reassembled the flex several times, placing the sensors in the correct position. The sensors are clean
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
Hi, some news: if I leave the phone with the display facing down and someone calls me, if I put the phone to the ear, the display doesn't turn off. But if I put the proximity sensor on the surface where the phone was first, the display goes off.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Vito Gravante 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 2
전체 시간: 2,730
