주요 콘텐츠로 건너뛰기
2009년 3월에 소개된 The Mac Pro (Early 2009)는 Intel Nehalem 아키텍처를 Apple의 전문가용 데스크탑 라인에 도입하였으며 미묘하게 재설계된 내부는 2010 및 2012 CPU 업데이트를 통해 소개되었습니다.
201 질문 전체 보기
4,1 to 5,1 Firmware tool saying no internet access Solved
Having an issue updating Mac Pro 4,1 to 5,1 firmware. After following the instructions for set up (disable SIP, have 1.5 pkg on the desktop), when trying to run the firmware tool I get "This program requires Internet Access. Please connect your Mac Pro to the Internet and Try Again" even though I am connected with ethernet. I can not find a solution. Firewall on the Mac is off so I am at a loss. Can anyone help? (I am new to forum posting, please forgive any errors)
Update (05/26/2018)
I discovered that the replacement router I received from my internet provider a few months ago had the firewall settings to high. I set it to a lower level and the firmware tool worked right a way. Hope this can help someone else who may encounter this problem. Thank you as well to the member who responded to my question.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 3
댓글 달기
답변 3개
가장 유용한 답변
The information on this discussion of the problem may help solve your problems:
Installation of High Sierra 10.13 on unsupported Macs
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
I can confirm that the issue, if you have ruled out all possible chances your internet is actually not working , is in the router. I went loco with this !
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Changing my router’s firewall setting to Low instead of Medium fixed the issue for me to. Thanks!
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
James 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 14
전체 시간: 1,211
