주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Anker Soundcore Pro는 2018년 Anker에서 출시한 휴대용 Bluetooth 스피커입니다. 모델 번호: A3142, AK-A3142013.
Where/How do we start opening this speaker?
Having the device not turn on now (similar to this), and having the device refunded already, I can tinker with this speaker any way I want it. One goal: to possibly find out the problem, and fix it.
The thing is, there is no obvious hole or secret thing to be screwed out or peeled off to get it opened, unless it requires peeling off the whole rubber skin of its bottom/feet..
I found this site which looks at its disassembled parts, but it's just that: already disassembled parts. The holes there suggests maybe screws, but...this speaker seems closed shut.
I tried opening it with the iFixit Pro tools I have, but to no avail.
...Maybe I have to pry harder? I might be fighting my way through adhesives here.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 1개:
How do you take apart a song core Bluetooth speaker where do you start taking it apart
의
댓글 달기
답변 4개
The front speaker grille pries off with a metal spudger (am I spelling that right?). The Torx heads are where the six posts slide into the front plate / speaker mount. They are style only and don’t unscrew.
Remove the ten screws; six across the top, four across the bottom. Two arrows show where to insert your spudger to pry the speaker plate out. Boom! You’re in!
On mine, the back of the micro USB input had come out and the jack’s tab to hold it weakened. I unplugged and removed the speakers, battery pack, & back port assembly. The assembly has two screws and needed some force with the spudger to loosen the adhesive holding it in. But it came apart with no damage.
I put all back in place and applied a blob of hot glue to the back of the micro USB jack to hold it together.
It all went back together just as easy and works fine now.
Cheers
이 답변이 도움이 되었나요?
점수 0
댓글 2개:
Worth trying. Why do micro-usb plugs fail so easily?
의
Hi motokam, I really like this illustration but it's quite difficult getting around the terms such as metal spudger, torx heads etc. If you please, I'd really appreciate a visual representation of the disassembling of the Anker soundcore pro speaker.
의
댓글 달기
이미지
There are only eight screws inside mine. The back feels like it's still attached at the top. Any advice?
이 답변이 도움이 되었나요?
점수 0
댓글 2개:
The newer Soundcore Pro+ perhaps? But from the images around, Pro+ looks no different.
Your speaker, at least from this image, looks to be a different speaker than the Soundcore Pro in question.
의
This speaker is different from soundcore pro speaker.
의
댓글 달기
Hi Leydar, Take off speaker grill, remove 8 screws. Turn over to back, gently remove back cover( tab in middle top, I had to lossen entire back before tabs would let loose). You now have access to insides. Good luck…
이 답변이 도움이 되었나요?
점수 0
댓글 달기
the top comes off first with clips
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Lloyd Dunamis 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 8
지난 30일: 56
전체 시간: 12,327
