주요 콘텐츠로 건너뛰기
D1760-2 DECT 6.0 Cordless Home phone with caller ID.
190 질문 전체 보기
Why will myVoicemail through Comcast will not allow recorded messages.
I have voicemail properly set up thru Comcast, but when you call the number it will not allow the Comcast voicemail to work. Comcast says it is the phone. I need to get this resolved asap!
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 1개
선택된 답변
Hi @mbrandall55 ,
Are you trying to remotely retrieve any recorded voicemail messages by calling the number with the voicemail facility from the uniden phone?
If you are trying to remotely retrieve voicemail messages what happens when you call the number and press the # key on the uniden phone during the voicemail's recorded greeting? Are you being prompted to enter a password?
If the voicemail is connected to the uniden's phone number how are you accessing the voicemail facility?
Are you dialing the full access number, pressing # during the recorded greeting and then manually entering the password etc or have you programmed the phone to enable 1 key (Message/Mute) key) operation?
Here's a link to the User manual. Scroll to p.13-14 to view how to set up and to edit the voicemail access and number.
Be aware of the need to insert the 4 second pause between the number and the password to allow time for the call to be answered by the voicemail facility and when the password will be sent automatically. (see p.14 Editing your voicemail number sect.2).
if it takes longer than 4 seconds for the voicemail to respond after you have called the number, then perhaps this is why it is not working. What is the ring time duration (number of rings) that you have set before the voicemail answers? You can alter this in your Comcast account to a more suitable number. If you cannot get the time short enough, I’m not sure if you can extend the “pause” time between the number dialed and the password dialed by including more ‘pauses’ in the setup but it may be worth a try.
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
귀하의 답변을 추가하세요
Mary Randall 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 5
전체 시간: 200
