주요 콘텐츠로 건너뛰기
2015년 9월 25일 출시. Model A1688/A1633. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 6, 64, 또는 128GB / 은색, 금색, 스페이스 그레이 및 로즈 골드로 제공하였습니다.
2690 질문 전체 보기
Auto brightness settings not working in iPhone 6s
Changed my front assembly with ifixit pre-installed assembly, just had to put the home button from old cracked screen. Now auto-brightness function disappearred from the settings. Tried everything, all other sensors are working perfectly. Any suggestions?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 2
댓글 달기
답변 4개
선택된 답변
If your replacement screen came with the Front Camera & Sensor Flex pre-installed, then it may be a damaged or defective flex. This is not uncommon as replacement small parts tend to have high defect rates. It's always best to transfer over your original flex that way you have Apple original parts.
So check out this guide and put your original flex in the replacement screen to see if that solves your problem.
해당 답변은 도움이 되었습니까?
점수 2
댓글 2개:
Changed the flex from old screen, everything working fine except auto brightness
Try a hard reset and if that doesn't work, do a backup and then a full restore to see if that helps.
댓글 달기
Try reseating the cables into the phones motherboard there mught be tiny particles preventing sufficient contact. Maybe try looking in your phones battery settings as auto brightness helps battery life. Let me know if this helps, Good Luck!
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
I tried it, its still not there
댓글 달기
Hm did the screen have all the sensors in it or was it the one without them
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Hi, If you already tried LCD and all flex, it should be the logic board problem. Backlight IC or filters are probably damaged due to quality or electric problem.
And the picture, it is the solution for similar problem on iPhone 6. I will try to find the same picture for iPhone 6S.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Johannes Gasser 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 4
전체 시간: 2,801
