주요 콘텐츠로 건너뛰기
This page shows you repair guides, tips and tricks of Huawei Honor 9, released in June 2017.
22 질문 전체 보기
I did a stupid thing and put my phone down the toilet!
I have a Honey 9 phone - dropped in toilet! has started now but can't unscrew back to check further damage. My camera and torch doesn't seem to work. I can still see drops of water in camera so how do I unscrew the back to let it dry out completly?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 해법
Hi @roni_james ,
As you know liquids and electronics and electricity are not a good mix.
The impurities in the water causes corrosion and provides circuit paths for the electricity which were not in the phone's operating design and could damage the components. The corrosion process starts immediately and continues until it has been cleaned properly
First do not turn on your phone and then you need to remove the battery as soon as possible from the phone to minimize further damage.''
Then you need to dis-assemble the rest of the phone and clean all the affected parts using Isopropyl Alcohol 90%+ (available at most pharmacies), to remove all traces of corrosion and water. Do not use "rubbing alcohol" as in some cases this is only 70% IPA or less, can contain scents and is not as effective. If you do check the label to verify the amount of IPA
Here is a link that in general, describes the process.
Electronics Water Damage
As always with electronics, especially surface mounted PCBs be gentle when handling and especially when brushing away the corrosion. You do not want to remove any components from the board.
Hopefully after you have done all this the phone might possibly work correctly again.
Here is a link to the ifixit Huawei Honor 9 guide(s)on how to repair some parts of your phone. It is useful as it shows how to dis-assemble your phone so that it can be cleaned properly.
If this process seems too daunting, take your phone to a reputable, professional, mobile phone repair service, experienced in water damage repair and ask for a quote for a repair.
If you decide to do this, do it sooner than later.
해당 답변은 도움이 되었습니까?
점수 3
댓글 달기
귀하의 답변을 추가하세요
RJ_UK 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 18
전체 시간: 177
