주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
iPhone 3G의 향상된 버전으로, 더 빠른 처리 속도를 자랑합니다. 이 기기의 수리는 3G와 유사하며, 간단한 스크루드라이버와 도구만 있으면 됩니다. 모델 A1303 / 8, 16 또는 32GB 용량 / 검은색 또는 흰색 플라스틱 뒷면.
unknown IMEI and ICCID
Shows unknown IMEI and ICCID
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 14
댓글 2개
please browse through the solutions to the right, this has been covered really well there.
의
also check out the solutions in iphone 3g
의
댓글 달기
답변 6개
선택된 해법
Most of the time that error is because the battery is not giving juice to the boot loader chip, try first to change the battery since the boot loader only will work from the battery power even so if the phone is directly connected to the outlet.
이 답변이 도움이 되었나요?
점수 9
댓글 2개:
+have seen bad battery give these signs many times.
의
Imei:013268003346713 iccid: unknown
의
댓글 달기
해당 답변은 원래 다른 질문에 답변 된 것입니다.
This is a very bad warning. The problem could be many things, water damage, hardware failure. But lets go with something you can try. A DFU mode restore. Open iTunes on computer. Connect iPhone to computer. First push Home button and then push Power button, count 8 seconds and let go of Power button, keep holding Home button until iTunes says it has detected iPhone in Recovery Mode, then let go of Home button (usually about 15-25 sec). The iPhone screen should be blank (black), if an image is on screen you are not in DFU mode. If in DFU mode then click to let iTunes restore your iPhone. If not in DFU mode, try to enter DFU mode again. Even experienced users can have a bit of trouble entering DFU mode, keep at it until you get it into DFU, iTunes will tell you when (Recovery Mode window), as long as screen is blank (black). Good luck. Brad
이 답변이 도움이 되었나요?
점수 5
댓글 1개:
Most times this will end in error 23... Cannot restore. The problem ic requires soldering skills and tools only professional repairers have. Let us know what you get with dfu and how you want to proceed
의
댓글 달기
chang the battery and see if ur battery is deamag it will work.
Update
i agree with u. but some cease is different battery is good imei iccd is unknown.any solution ?
이 답변이 도움이 되었나요?
점수 5
댓글 달기
iphone imei unknown iccid unknown
이 답변이 도움이 되었나요?
점수 5
댓글 3개:
의
8997103113101650188
의
iPhone iemi unknown iccid unknown
의
댓글 달기
I used to have the same problem no imei no iccid, after i change battery everything start working.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
it is the battery. I just fixed mine.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
advinsp 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 15
지난 30일: 31
전체 시간: 38,440
