주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
링컨(Lincoln)에서 제조한 풀사이즈 럭셔리 세단인 1세대 Town Car의 수리 안내서와 지원 정보입니다.
Factory Keyless entry code
What is that factory keyless entry code
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 2개
가장 유용한 답변
It is likely posted on a sticker placed under the dash, usually on the keyless entry/anti-theft module. You almost have to be a contortionist thou to be able to read it, as it can be up under the dash pretty high. The dealer can retrieve the code via computer, BUT that usually involves a fee (unless you bought the vehicle from them, then they might do it for free). Ford's I've owned have always had the keyless entry code visible way up under the dash, and I've found it easier to view them by holding my camera under the dash with flash on and snapping pics rather than abusing my neck.
Or it can be located in the truck on the bar that controls the trunk to open you will see it when you pop trunk open
이 답변이 도움이 되었나요?
점수 1
댓글 달기
On my 1987 Lincoln Towncar, it’s right of glove box very easy to see code if sticker is still on it the only thing I move is the cover under the glove box . Fordman…
Update (04/06/2020)
Yes it’s for the keyless entry door pad code on my 1987 Lincoln Towncar right of glove box just above kick panel very easy to see with flash light it’s a black box with wires plugged in it.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
James dill 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 8
지난 30일: 33
전체 시간: 3,790
