주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Macintosh Powerbook 140은 초기 Apple 노트북 컴퓨터였습니다. 이 노트북은 대형 전원 케이블, 배터리, 트랙 패드 대신 트랙볼을 포함하고 내장 플로피 디스크를 사용하는 최초의 Apple 컴퓨터 중 하나였으며, 키보드 높이를 조절할 수 있었습니다. 또한 키보드를 컴퓨터 본체 뒤쪽으로 장착한 최초의 노트북이었습니다.
PowerBook 140 Boot up issue
Hello,
For quite a long time, I have been repairing an old PowerBook 140. The comuter had mnay issues with parts that I have mostly remedied with eBay purchases. However, I am still having trouble getting it to function completely. Whenever I boot up the computer, it gives my a grey screen and nothing else. When I use the reset buttons on the back of the computer, one of two things will happen - the computer beeps, makes a whirring noise (I believe it's the hard drive spinning up), stops, and repeats the entire process again. When this does not happen, the computer makes a poping noise and the screen flashes. This happens quickly, eventually slowing down over time. Also, on other occasions, the computer will be completely unresponsive, but I think this is caused by a poor battery and charger.
I believe the former two booting errors are caused by the hard drive. I may be wrong, but when I booted the computer with a different drive it worked well. I would, however like to use the original hard drive, as it has personal files on it. I attempted to retrieve the hard drive's information with a USB to Hard drive adapter, but was unable to do so with either the orginal or operational hard drive.
So overall I have quite the predicament on my hands.I have tried to be as descriptive with my problem is possible. If anyone knows any potential fixes for this issue or even any idea of what the issue is, I would be very grateful for your assistance.
Thank you!
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 1개
One other item of note - the original hard drive and the functional one are the same size but different models
의
댓글 달기
답변 1개
가장 유용한 답변
Well, if that original hard drive is bad you don’t stand a chance of using it. Put the new drive in and install a system from the original installation disk. Now, if you have a running machine, you have a shot at recovering your old files by putting the drive in an external enclosure or using a universal adapter.
Here’s how to install the new drive: Mac Powerbook 140 하드 드라이브 교체
이 답변이 도움이 되었나요?
점수 2
댓글 달기
답변을 추가하세요
Jack 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 13
전체 시간: 655
