주요 콘텐츠로 건너뛰기
PC 및 Mac 컴퓨터의 RAM 저장 장치 수리 안내서 및 지원
45 질문 전체 보기
if I can install a bigger ram
if i install a bigger ram,will i be able to download stuff?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 1개
That depends on what you want to install it into.
댓글 달기
답변 4개
가장 유용한 답변
I'm not sure here, but is BOSS not confusing hard drive storage and RAM?
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
That really depends on the size of your ram. If you assume a typical ram to be between 45-160 KG, then I think you could get an extra 200-300 GB of storage.
However, you'd need to check that your motherboard has the capacity to take the extra ram. And don't forgot that it's a lifetime commitment; you'll need to feed it, pay vet bills, and generally look after it like any other pet.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
The RAM of a system does not store any of your data, that is the job of the hard drive. The closest thing it could effect is the speed of dowloads, which, since you are upgrading it, would make it faster. The only way it could affect your ability to dowload is if your computer had no RAM, in which case it simply wouldn’t turn on.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
more ram doesn’ t give you extra space to download games. it helps you to open more browser pages, for instance.
if you want to have extra space it is the hard drive you need to improve.
extra ram will only boost your performance.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
B0SS NIGGA'S 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 6
전체 시간: 82
