주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
이 수신기는 PC에서 모든 Xbox One 무선 컨트롤러를 무선으로 사용할 수 있도록 합니다. 이 어댑터는 Xbox One 컨트롤러의 PC 연결성을 제공합니다.
How do I fix the controller driver?
I am having an issue with my Xbox wireless receiver in Windows 7 x64 (Pro, if it matters). When I connect my controllers in my fleet I still use (Repaired 1708 and new backup 1708) I cannot control my games with either of them. I can confirm this happens on both my 1708 controllers. I tested my mostly neglected Model 1697 controller as well, and it still happens. It's not a 1708 problem; it happens on all of my controllers.
I went into Device Manager and found a Code 54 error for my controller. I uninstalled and removed the driver, but the controllers no longer register. I did not restart my computer when I made this change, since this typically isn't required. I need the control to register to install the drivers from, so I need to at least get the controllers working as unknown devices so I can go into Device Manager and reinstall the driver from scratch. I also tried USB since I don't care about the receiver in this application, but I still didn't get anywhere.
Is there anything I can try to fix this to the point I can get Device Manager to show my controller again so I can reinstall the driver and get it working again? It works on my other computer running Windows 7 x64, so the problem is isolated to one PC.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 2개
선택된 해법
I have solved the problem. What I did to resolve it is update HID Compliant game controller with the following VID references:
  • HID\VID_045E&PID_02FF&IG_00
  • HID_DEVICE_SYSTEM_GAME
  • HID_DEVICE_UP:0001_U:0005
  • HID_DEVICE
I located this and told it to find the driver online and it fixes the Code 54 problem. The driver it installs from Microsoft Update Catalog is correct and does not need to be changed.
이 답변이 도움이 되었나요?
점수 3
댓글 달기
pour rpr une xbox il faux debranche le cable de xbox et rebranche le cable
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
set ne pas du fake donc itulise cette astuse
의 공유
댓글 달기
답변을 추가하세요
Nick 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 8
지난 30일: 40
전체 시간: 3,849
