주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Kyocera Hydro Vibe는 4.5인치 충격 방지 스크린과 Smart Sonic 수신기 기술을 탑재한 방수 터치 스크린 폰입니다. 모델 번호는 C6725입니다.
Kyocera Duraforce Pro USB Charging Question
I have three of these phones.
I just replaced the screen on one using a screen from a phone with a blacklisted ESN.
I put he cracked screen on the bad ESN main board and it works even with the cracked screen.
Here is my question.....
All three phones charge wirelessly.
Two of the phone will charge with any USB charger I use.
The third phone will not charge with any charger I have. Including a Q2 rated charger.
I get an error message stating that I must use the original charger. Which I do not have.
I suspect this is either a firmware or a hardware related situation.
Does anyone have an idea if this can be changed.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
선택된 해법
Ok.... Problem Solved
I decided to swap out the USB charging port to see if this was the problem.
Turns out that it was. The phone would see voltage but apparently one of the data lines on the USB connector was bad. Charger and phone could not communicate.
이미지
이 답변이 도움이 되었나요?
점수 3
댓글 2개:
Anybody finding anything other than used parts to replace this port?
의
I can also only find used parts. Anyone have a time estimate on the charge port replacement?
의
댓글 달기
답변을 추가하세요
BayArea Exploration 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 25
전체 시간: 4,242
