주요 콘텐츠로 건너뛰기
모델 번호 A1238 / 80, 120, 또는160GB 하드 드라이브 / 검정색 또는 은색 금속 외형
904 질문 전체 보기
No content but drive is packed?
Noticed that my 160cg classic was showing "no songs". So after a restore the songs were back. Then later on I attempted a sync and it shows no content again. About screen shows 130gb of "other" but the songs are on there. Tried restoring a few times. Music stays till I sync it again or even plug it into a dock. Tried formatting it fat32 as well without joy. Any help is greatly appreciated.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 달기
답변 1개
선택된 답변
bazo, it has been my experience that if you can not format the drive, it needs to be replaced. Had the same issue recently and messed around with that for a good while. I could see the files etc but had no access to the, failed format. The only thing that fixed it was a new drive. It looks like you already tried everything else as well. Good Luck
iPod Classic Hard Drive Replacement
해당 답변은 도움이 되었습니까?
점수 3
댓글 4개:
It formats fine though. I can reformat it to any file system and use it as removable storage perfectly. And if I restore the ipod on mac, It works perfectly. But then if I plug it in to sync it all goes to *@*%. The problem is that it's quite an inconvenience to sync 130gb of music every time i want to add a new song :( Thank you for your reply though oldturkey03 :)
Sorry I must have confused this somewhere when you originally stated that "Tried formatting it fat32 as well without joy" I took it as not formatting. To copy additional songs to your ipod for syncing, you could just pull the song from your library to your ipod and it will transfer the individual song and not all songs. So I guess the issue is not your ipod but your iTunes :-) good Luck
@bazo i dont understand? how is it that you restored your ipod and your music magically appeared? If i'm not mistaken, the purpose of the restore action is to completely erase all your music and restart fresh?
He did not say it "magically appeared" He is resyncing it. So the music is probably on his computer in the iTunes library...;-)
댓글 달기
귀하의 답변을 추가하세요
bazo 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 1
전체 시간: 7,932
