주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
-EF 마운트 렌즈 -조리개 범위: f/3.5-36 -광학식 이미지 안정화 -초음파 자동 초점 모터 -내부 초점 시스템 -수동 초점 오버라이드 -최단 초점 거리: 50 cm -72 mm 필터 나사산 지름
Zoom not working broken?
I'm not sure that this is the same lens as mine but this is my problem: I was trying to but my camera in the bag but the zoom was all out so it wouldn't fit. I tried to zoom out and I did but it was stuck and I had to force it a little and after forcing it it doesn't zoom in anymore. The ring turns perfectly but it does nothing. I also hear a little noise inside like a lose peace? Did I broke my lens?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 3
댓글 달기
답변 3개
sigma 50mm f/1.4 ex dg hsm
이 답변이 도움이 되었나요?
점수 0
댓글 달기
gopal jograna nagpur
123456789
이 답변이 도움이 되었나요?
점수 0
댓글 달기
For future reference, it's typically never a good idea to force the zoom ring to move if it's stuck like that. What could happen, which happened in your case, was that you were putting a lot of strain on some internal component and it eventually got to the point where it just snapped.
Whenever you do need to zoom a lens in or out to get it to fit into a camera bag, make sure to only do so using the zoom ring. Avoid pushing or pulling on the lens to zoom. It can put extra strain on components or put strain on them in a way that they weren't design to handle.
As to your question of whether or not it's broken, it definitely is. The mechanical connection between the zoom ring and the internal zoom lens elements have been severed in some way, which is how the zoom ring still turns fine while not actually effecting the zoom. The noise you here in the lens is most likely a screw or broken piece(s) of plastic. To know exactly what broke inside it, the lens would just have to be disassembled and examined.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Miriam Granadas 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 7
지난 30일: 35
전체 시간: 1,233
