주요 콘텐츠로 건너뛰기
Announced in August 2017년 8월에 발표된 Galaxy Note8을 회수된 Galaxy Note7의 후속 모델입니다. Note8은 대중이 구매할 수 있도록 2017년 9월에 공개되었습니다.
141 질문 전체 보기
My S Pen broke off, half still inside, how can it be removed?
Help get SPen out of phone?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 3
댓글 2개
I used a lock picking tool it had a hook on It tried for 30 min then I prayed put it back in felt it move and out it came .
Grateful it worked
댓글 달기
답변 4개
선택된 답변
Smack the bottom of your phone or lightly hit it on a table, it should come right out when you shake it!
해당 답변은 도움이 되었습니까?
점수 7
댓글 5개:
This worked for me, thanks.
purrrrfect solution , thank you
Worked for me too thanks!!
This worked thanks alot. ?
Worked great for me. Thanks!
댓글 달기
Tweezers? Here is a video of someone getting one out:
https://www.youtube.com/watch?v=zA5xYT-x...
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
My S pen broke outside phone and i put it back in there Not thinking. The pen came out but part of the plastic encasing remained inside. How can I get this to come out?
댓글 달기
Mine was stuck way inside the phone. I used a drill with a tiny drill bit and drilled into the hole in the stuck s pen. All you have to do is simply pull it out. It ruins the s pen, but you can get a replacement on Amazon
해당 답변은 도움이 되었습니까?
점수 1
댓글 2개:
you can use a phillips screw driver and insert it inside. it worked best for me to take out the broken s pen inside.
Yay! the screwdriver is the only thing that worked for me! thank you so so much!
댓글 달기
I used the old-type iron twist serving to prepare a hole in the wood plate for screwing-in the screw. I think this is the best solution!
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
Robin Kamps 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 10
7일 전: 65
30일 전: 283
전체 시간: 20,493
