My S Pen broke off, half still inside, how can it be removed?
Help get SPen out of phone?
좋은 질문 입니까?
좋은 질문 입니까?
Tweezers? Here is a video of someone getting one out:
해당 답변은 도움이 되었습니까?
My S pen broke outside phone and i put it back in there Not thinking. The pen came out but part of the plastic encasing remained inside. How can I get this to come out?
Mine was stuck way inside the phone. I used a drill with a tiny drill bit and drilled into the hole in the stuck s pen. All you have to do is simply pull it out. It ruins the s pen, but you can get a replacement on Amazon
해당 답변은 도움이 되었습니까?
you can use a phillips screw driver and insert it inside. it worked best for me to take out the broken s pen inside.
Yay! the screwdriver is the only thing that worked for me! thank you so so much!
I used the old-type iron twist serving to prepare a hole in the wood plate for screwing-in the screw. I think this is the best solution!
해당 답변은 도움이 되었습니까?
24 시간 전: 3
7일 전: 26
30일 전: 172
전체 시간: 21,833
댓글 2개
I used a lock picking tool it had a hook on It tried for 30 min then I prayed put it back in felt it move and out it came .
Beth ann Poole 의
Grateful it worked
Nintai Neville Nfor JR 의
