주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Whirlpool 브랜드의 상단 및 전면 투입식 세탁기에 대한 수리 안내서 및 지원입니다.
Why I can't access diagnostic mode
I installed a new control board and machine won't go into diagnostic mode. What is next step?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 4
댓글 1개:
What is your model number?
의
댓글 달기
답변 3개
Is it a top load with no dial? Cabrio? If so turn it on and unplug and wait till it goes dead “ youll be impressed how long” and then wait three minutes, take a screw driver and touch the two flat leads on the plug in together “unplugged of course” then plug it in with the lid down, open the lid for sec or two then close it, used three buttons as like 1,2,3. Press 1,then 2 then 3 in normal sorta motion three times in a row, if it has a dial and the sensing, wash done spin lights under the knob, turn it a few times left, “all the way around”then right. Right. Right. Left. Right. Not to fast not to slow, every fail try, spin left few times again.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Press each button, if you see buttons responding (like LED blink whenever you press a button), this means touch pad or buttons are working. If you became certain that all buttons are responding but unit still won t go to test mode, check door switch, if switch is OK…then it must be the control board.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
My whoorlpool top load washer will not go into diag mode no lights will light up only the green light inside on the control board And the pump runs constently
이 답변이 도움이 되었나요?
점수 0
댓글 2개:
Hi @philip90310,
What is the model number of the washer?
의
this was EXACT problem but then when I unplugged one of the sensors to test it on the control board i just randomly tried to put it in diagnostics mode and it worked. but I still am not sure what the problem is....according to one video it is the sensor that is bad which does make sense bc it was flashing the sensing green light and humming every 20 min for 5 min intervals
의
댓글 달기
답변을 추가하세요
Dale Wasinger 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 25
전체 시간: 8,474
