주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2012년 Sony Entertainment는 2006년 출시된 PlayStation 3 콘솔의 새로운 버전을 출시할 것이라고 발표했습니다. 새로운 콘솔은 PlayStation 3 Super Slim이라 불리며 모델 번호 CECH-4000으로 식별됩니다. PlayStation 3 Super Slim(CECH400x)은 Sony Computer Entertainment에서 생산한 PS3 게임기 버전 중 세 번째 제품입니다. 2012년 10월 25일에 출시되었습니다.
disc not reading and spins then stops..
Hello, I am needing help on fixing on my ps3 super slim. I'm trying to play a game on it and it spins then stops about three times, and it won't show the disc icon with the name of the game. Can anyone help me with this situation??
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 4개
Hi @therealrjrios try with another disc type, e.g. dvd video.
Does it works ?
Hello @salmonjapan , yes every single game I had did not work. as I did mention in my question, it won't show the disc icon with the name of the game.
Mine plays cd’s and dvd’s but doesn’t play or ID any of the Game disc’s?. It’s like it starts to spin up and actually Read the Game disc and then fails to relay or read the
data ?
Forgot to mention that i did install a brand new blueray dvd drive.
댓글 달기
답변 3개
가장 유용한 답변
When a disc is loaded, the system attempts to read the TOC (table of contents) of the disc. This is the spinning that you hear. If the TOC is not readable, the spinning stops. This will be attempted 3 times (sometimes more). In your case, the disc is not readable. This can be as simple as dirt on the DVD lens or a failure of the laser itself. If you can gain access to the drive, try cleaning the lens (carefully) using a cotton swab and alcohol. This may resolve the problem. If not, then replace the drive.
You can get the laser assembly for around $15 and the entire drive for around $40.
Dan
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
the game im getting issues with is Driver San Francisco where everything is fine until i try and load the mission where i prove to jones that i can "shift" as i get to the loading screen where within 90 seconds the disc will completley stop spinning
댓글 달기
I replaced the entire set up. It read the disk finem then when I came back to it, it stopped. It just spins and clicks.
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
I find a well deserved threat or slight WACK with a fist or small footed person helped. Other option is to place it firmly against a wall from 6 foot away. Then put it in a bin. Sorted
댓글 달기
Ok so I had this same problem but I was able to fix it ok,so I know you might hear/see this a lot on the Internet as a solution "cleaning or replacing the laser",now for the PS3 super slim you are able to clean the laser without having to dismantle the entire thing just open up where the disc goes and you'll see two little glass circles, get a cotton tipped applicators non-sterile aka qtip and just gently rub it against those two glass circles and around it and that should fix it,it did for me but also make sure that your disc has no scratches and is also clean i hope this helps.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
RJ Rios 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 4
지난 7일: 18
지난 30일: 84
전체 시간: 18,344
