주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2015년 10월 25일에 출시된 Afterglow Prismatic 유선 컨트롤러는 비디오 게임 액세서리 업체인 PDP에서 제작한 Xbox One 컨트롤러입니다.
The left thumbstick clicker button will not click...
Hi guys. My son's Xbox One Afterglow controller's left thumbstick button will not click when the thumbstick is pushed forward. This is super annoying when trying to play Battlefield 1, because that happens to be the run button.
Couple of things :
I dunno how the damage was done, my son did it and he's pleading the fifth...
The button does click on almost all other positions and there seems to be no catchiness in the movement of the thumbstick.
I have noticed the left thumbstick will pull up almost half a centimeter, whereas the right has zero upward play.
Any suggestions or answers you already know are very much appreciated. There had been an aborted attempt to open up the controller but I was weary on how much force should be required to separate the two halves of the case. But I plan on a reattempt...
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
Its sounds to me like the joystick assembly for that side has broken. These parts are mad from plastic and are not the most sturdy of parts. A replacement part can be installed if you can solder. The part shold run about $6-$8.
Dan
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
how do i do this??? like how do i get it installed???
의 공유
댓글 달기
답변을 추가하세요
Jeremiah 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 8
지난 30일: 26
전체 시간: 6,186
