주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Garmin Nuvi 255W는 GPS(위성 위치 확인 시스템)입니다.
keyboard not working properly
When I'm trying to enter an address, the right side of the keyboard is off by one key (e.g. J becomes k). Lately, the only thing that works is "Go Home." Will replacing the screen correct this?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 3개
가장 유용한 답변
I found the following and it worked, though I did have to do it several times.
Here are the instructions to do the recalibration of your keyboard.
1) Turn off your Nuvi
2) Press and Hold the upper left corner of the screen and at the same time turn the unit on.
3) When you see the screen appear, release the power key, but keep touching the screen.
4) In about 30 seconds, a screen should appear that says "press the dot", and 5-7 dots should appear around different parts of the screen. Press each dot as it appears.
After the calibration is done, you should be taken back to the main screen. From that point TEST the different keyboard keys and they should work better. If not, try again.
https://www.justanswer.com/gps/5jhpw-gar...
이 답변이 도움이 되었나요?
점수 1
댓글 달기
you might be able to calibrate it from settings,or just by a factory default
이 답변이 도움이 되었나요?
점수 0
댓글 달기
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Ellen Houghton 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 29
전체 시간: 1,859
