My charging port is messed up
hi my charging port is messed up, keeps going On and OFF and in the middle of the route.What can I do to fix loose port?
좋은 질문 입니까?
좋은 질문 입니까?
use this guide Garmin Nuvi 1390LMT Logic Board Replacement to get to the port. It is soldered to the mainboard. You could check and see if a resolder might fix it (if one or two of the contacts are loose). Worst case would be to replace the port. Hardest part on that would be to source a replacement. Once you have the board removed, post some images of your port etc. with your question. That way we can see what you see. Use thius guide 기존 질문에 이미지 추가하기 for that. We might find other solutions based on what we see.
안내서
난이도:
아주 쉬움
2 - 5 minutes
안내서
난이도:
운영
15 - 35 minutes
해당 답변은 도움이 되었습니까?
24 시간 전: 2
7일 전: 4
30일 전: 9
전체 시간: 158
