Water damage under shield
Hello,
I have a water damaged Huawei P8 Lite. I opened it and found that a shield was hot when charging, there is water damage under it:
이미지
Several components are damaged, do you think I can break the shield that is glued on the board to clean it with isopropyl?
Do you think it is fixable and what is the reference of the component on the left that is entirely burnt? I think other components are capacitors, can I remove them without replacing?
Thank you for your help!
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
