주요 콘텐츠로 건너뛰기
The Xbox One S, designed by Microsoft Corporation, was released on August 2016. The Xbox One S is a redesign of the Xbox One.
428 질문 전체 보기
I am trying to connect speakers to my Xbox
I am trying to connect my speakers to my xbox one s directly because my tv doesn't have an audio port. But my xbox does and it won't recognize the speakers unless i plug them into the controller.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 3개
선택된 답변
Hi
As the Xbox one s does not have a 3.5mm audio output, you will need a HDMI to HDMI + audio adapter like the one linked below. This will use the HDMI port of your Xbox and give you a audio out as well as HDMI.
Good luck
https://www.amazon.de/AAMANKA-HDMI-Audio...
해당 답변은 도움이 되었습니까?
점수 2
댓글 3개:
Thank You so much I will look into buying it!
Hi, I’ve used one of these to connect headphones to my tv but the max volume isn’t very loud. Do you know how I could improve this? Thanks
I don’t have that exact one but I do have one similar it does not work
댓글 달기
Have the same issue with my Xbox 1x. My monitor has a headphone jack and audio in. Tried both and neither work and it only works through my controller.
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
The monitor will only work if you have a power source, HDMI cord, output to complete the circuit, and somewhere for the sound to go. If you have any problems after that, then press the home button, go to the Profile tab, press settings, and click on sound preferences. Hope this helps!
댓글 달기
I’m trying to connect my Xbox 1 S to our 4 built-in surround sound speakers without an optical output cord. Is there any way to do this?
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Jacob 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 7
7일 전: 39
30일 전: 137
전체 시간: 58,366
