주요 콘텐츠로 건너뛰기
2017년 11월 4일 출시. A1865, A1901. GSM 또는 CDMA / 64 또는 256 GB / 은색 또는 스페이스 그레이. ("iPhone 10"으로 발음합니다.)
1199 질문 전체 보기
Change only ear speaker
Hello, i have a question. I don't found it on iFixit.com.
I bought ear speaker (on the left side.) Ear speaker from iPhone X (on the right side).
How do i replace it? can i disconnect flex cable with microphone, ...? How?
Thank you :)
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
I don't have an iPhone X in front of me but the proximity sensor is soldered onto the ear speaker (the two gold pads). You should order an ear speaker that has the proximity sensor pre-installed, like this one here.
UPDATE
Currently there are all kinds of issues regarding Face ID and the Ambient Light Sensor. If these things are important, then you need to go to Apple to have the whole screen assembly replaced.
해당 답변은 도움이 되었습니까?
점수 2
댓글 3개:
Thank you. But what about face id problem. I read on the internet after change all of that , will be problem with Face ID.
According to my research, in the event I would have to do this (not personally tested yet), there are some integrations on the flex cable. If you change the cable out, it may (because I haven't tested it myself) affect the Face ID. A lot of things I've seen online are people soldering out the damaged parts from the flex and replacing them. The other issue is how sensitive the cable is.
So if someone has an issue with the Face ID after display replacement, it's because you need the original camera/speaker flex and you need to inspect for damages, because that piece is delicate.
If any of my brethren on here have worked on these devices and have seen otherwise, please advise with details.
Good Luck
I was just answering your question about how to connect the two pieces.
댓글 달기
귀하의 답변을 추가하세요
Michal Petras 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 2
전체 시간: 1,924
