주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
HP Officejet Pro 8620은 복사, 스캔 및 양면 인쇄 기능을 갖춘 다기능 프린터입니다. 이 기기는 모델 번호 SNPRC-1401-02로 식별할 수 있습니다.
Colours are printing with lines
Colours are printing with lines even after cleaning procedure as well warm water cleaning with syringe etc. Can you repair the head?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 3
댓글 달기
답변 3개
Your printer software should have the option to clean the print head. Try that.
이미지
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
that helps if the print head is still "treated as" ok.
usually only very little or parts of lines are not good.
의
댓글 달기
No luck in software or manual cleaning as stated.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
No.
Usually you can’t fix the problem once the lines remain over more than 1-2 prints.
Problem is the print head of course.
The real question is WHEN does it happen and WHY.
In my case (Officejet Pro 8620) the lines started appearing immediately (!) after placing non-HP catridges to the printer when out of warranty. This is actually very unlogic from a technical point of view, as there still is original ink in the print head.
That’s why MANY SAY and so I do believe that the problem is “caused” programmatically.
So you would need to buy a new printer or at least print head.
PROBLEM. There is no real proof for what I claim or believe. Why?
HP can argue differently and we can’t look into the internal communication of the print head, main board, etc.
but I’m actually thinking of doing that, because it is possible with the right knowledge and someone should check against fraud.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Pieter Basson 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 19
전체 시간: 987
