주요 콘텐츠로 건너뛰기
Model A1059 or A1099 / 20, 40, or 60 GB hard drive / touch sensitive click wheel
227 질문 전체 보기
how do you reconnect headphone cable
I was able to take apart my old ipod iphoto and replace the battery in it. However, I can't seem to get the heapdphone cable to reconnect on the reassembly end. Did I bend something? Can I fit it? Help!
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 2개
I suggest you check iFixit's Guide for that repair
Also you could look at this one
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
가장 유용한 답변
compare the orange cable end to the photo on step 9 here:
iPod 4th Generation or Photo Headphone Jack Replacement
Is the square black connector still on the end of the orange cable? If not, then you accidentally peeled the orange cable off of the connector, which is still in its socket on the logic board. You will need to order a replacement headphone jack board, and use tweezers or needle nose pliers to GENTLY remove the damaged black connector square from the socket on the logic board.
If the cable and connector are intact, it should be a simple matter to snap it back into the socket on the logic board - the cable routing will guide the connector to the socket with the correct orientation.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
rchinatti 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 4
전체 시간: 1,421
