주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
가스 구동식 및 전기 골프 카트(Club Car Golf Cart 브랜드에 따라 때로는 골프 카(golf car) 또는 클럽 카(club car)라고도 함)에 대한 지원 정보를 제공합니다.
Forward/reverse lever are backwards
Hi gang, I have a 2001 Club Car DS 4 stroke gas engine. Problem is small but it irks me that I cant seem to find the solution. When the cart is in the forward position it goes backwards and vice versa..,when its in the reverse position it goes forward. A little help please...chances are this is a simple fix but I guess I’m having a brain fart and cant figure it out.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 1개
That’s great looking into it now, I don’t see those studs but will explore a bit more.
Thanks a lot for your response, will keep you posted.
댓글 달기
답변 2개
선택된 해법
Look at the motor. On one end of the motor (the side closest to the gearbox) the studs will be labeled S1 and S2 (for a Series cart) or F1 and F2 (for a sepex cart). Take those two cables off and swap them and your problem should be rectified
이 답변이 도움이 되었나요?
점수 2
댓글 6개:
Simple, brilliant answer.
I’m not sure what a sepex cart is...you do realize that I’m talking about a gas engine right?
No luck finding the two studs to swap over the cables, just dont see it. Sorry....thanks for trying though, appreciate it.
댓글 1개 더보기
댓글 달기
The problem is someone has changed the motor. Earlier cc engines ran counter clock wise and the newer ones run clockwise hence your shifter works backwards
이 답변이 도움이 되었나요?
점수 1
댓글 2개:
So does this reverse the gearing as well? Reverse gears should be lower than forward gears correct?
This seems to be the correct answer as my cart is the same way.
댓글 달기
답변을 추가하세요
Den Gauthier 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 5
지난 7일: 20
지난 30일: 47
전체 시간: 2,506
